C6 ZO6 amp and speaker up grades help please!
Old 10-22-2011, 08:11 AM
67redrat
67redrat's Avatar
Default C6 ZO6 amp and speaker up grades help please!
Ok like most here, I've found in the most disappointing way that GM gave us an awesome car with a crappy sound system. guess they had to make cost savings somewhere. Anyhow I just got all my equipment together and I'm in the process of ordering the PAC ADD-GM24, but per the sonic site this is for the non nav units, I'm confused? Is this the wright harness? And the line leveler isn't necessary wright? Please help thanks!!!!!
Old 10-22-2011, 10:06 AM
EVRose
EVRose's Avatar
It is the right one. It will work. I have it on my nav HU and it works fine. I don't know what the line leveler is.
Old 10-22-2011, 10:35 AM
Thrash
Support Corvetteforum!
Thrash's Avatar
PAC ADD-GM24 will give you line-level output. Be sure to cruise all the posts here that cover this, as well as the FAQ's at the top ... very informative and a lifesaver ... My install plan is attached, going in a similar path to yours.
File Type: pdf
Old 10-22-2011, 05:08 PM
markcz
markcz's Avatar
http://forums.corvetteforum.com/audi...r-harness.html
Old 10-22-2011, 07:06 PM
pentavolvo
pentavolvo's Avatar
Cruise-In IX Veteran
it is proper harness... if you need it modded send to me i can do it for you
To C6 ZO6 amp and speaker up grades help please!
Quick Reply: C6 ZO6 amp and speaker up grades help please!
