Sponsored by: Innova
Big Thanks to Double D mods!!
Old Nov 20, 2011 | 06:05 PM
mdiiulio's Avatar
mdiiulio
Default Big Thanks to Double D mods!!
Just installed some new audio equipment from Dennis at DoubleD. Truly amazing new sound and the customer service couldn't have been better.
Now running:
Kenwood DNX9960 HU
Kenwood XR-5S amp
Focal 165 kr2x components
Focal 27kx sub in back with a stealth box
I put dynamat xtreme in the doors and the entire back. Also have Vette Nuts (formerly Madvette) foam/heat barrier throughout. Still working on tweet placement (should've bought 3M stock a long time ago).
...and no, I don't have pics. I've been a little busy putting this all together in just two days.
Again, a huge thank you to Dennis for making this all possible.
Old Nov 20, 2011 | 06:18 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
I am installing a set of Focal PS 165 door speakers too in my GS.
My OEM system was the standard non-Bose Delco audio system.
The easiest place I found to put the tweeters was just about where the OEM 3" speakers was:
In fact, to make this install easy, I am just going to mount the 2 crossover boxes that come with these speakers right here below the 6.5" woofer:
I can't see any reason to mount these crossover boxes way back to where my amp will be mounted.
Old Nov 20, 2011 | 06:29 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
water will get in the door, either cut into styrofoam on door panel or put xovers under the dash
Old Nov 20, 2011 | 09:40 PM
markcz's Avatar
markcz
For mounting the tweeter, get some 1/4" MDF at Home Depot and cut out a square the same size as your oem twiddler, then cut a hole in the middle of it to use the flush mount tweeter housing. It will mount in the exact same bolt holes as the original speaker.
Here are a few pics of the one I made for the 3-way active setup I'm working on....
Old Nov 20, 2011 | 09:54 PM
kedar's Avatar
kedar
St. Jude Donor '12
Tweeter install: either make your own speaker baffles or buy baffles from nakidparts or RAAMaudio.
Crossover install: you would be much better off installing them in the cavity above the passenger floor board. You can adhere them using 3m dual lock velcro tape. I have pica of this location in my install thread.
Old Nov 20, 2011 | 10:48 PM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
Thanks Zach!
Glad your loving the new tunes!
Thanks again for your business as well!
Dennis
0Double D Mods
Former Vendor
Wow
mentioning two other vendors in kudos thread to me when we actually included the baffles with his speaker purchase
Old Nov 20, 2011 | 11:09 PM
kedar's Avatar
kedar
St. Jude Donor '12
Originally Posted by c5 BearsFan
Wow
Sorry buddy, we all know you have outstanding service and prices. When I get a head unit I would not consider getting it from anyone else. I was just responding to Turbo6TA's questions which probably belong in their own thread... Also did not know you have baffles.
Old Nov 20, 2011 | 11:13 PM
0Double D Mods
Former Vendor
just wasnt like you is all
To Big Thanks to Double D mods!!
