Sponsored by: Innova
OK, so Liquid Nails doesn't work, now what?
Old Nov 22, 2011 | 12:57 AM
427Z0SX's Avatar
427Z0SX
Default OK, so Liquid Nails doesn't work, now what?
I wanted to attach 4 bolts to the bare hatch floor, in order to anchor a wooden board to mount the amp and crossovers. After 2 days, the bolts just popped off with light finger pressure, the glue still feels kinda rubbery. Maybe due to the cold temp around here? 40s at night, car is parked indoor, so maybe 50s inside the garage. What can I use to firmly glue the bolts? Thanks,
Old Nov 22, 2011 | 04:44 AM
icanski2's Avatar
icanski2
St. Jude Donor '13
Rough the surfacees up with some 80 grit sand paper and use some Loctite 5 Minute Epoxy or better yet some Loctite Epoxy Plastic Bonder. Avoid the one minute or instant stuff because it is not as strong. You can get the stuff at Home Depot type places.
Old Nov 22, 2011 | 06:41 AM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
Yup ... I glued a board on the wall behind my passenger seat for my amp (the board sets vertically). The 5 minute epoxy holds perfectly.
Before glueing on the board, I drilled 4 holes in the board and inserted 4 threaded 'collars'. These collars will accept the threaded screws that will attach the amp to the board.
Old Nov 22, 2011 | 06:56 AM
Turbo6TA's Avatar
Turbo6TA
Looking at your photos, you might be going about this the wrong way ... the glue may not be strong enough to hold just those bolts to the floor.
Glue the back of the board directly to the floor, then screw the amp down to the board. That will give the epoxy a larger area to hold the board, and the bond won't fail.
I wish I had taken a photo of the threaded collars that I inserted into the board before glueing the board down .. but, unfortunatly I didn't. Anyway, I got the collars at Lowes (in the section that has all the stainless nuts and bolts and various fasteners).
The collars will push into the back of the board.
Old Nov 22, 2011 | 10:58 AM
Thrash's Avatar
Thrash
I'm planning to use elevator-bolts (they have a big flat 1" head) and lots of premium epoxy, to hold my digital processor and maybe an amp behind the pass. seat, less thickness than using the board ...
Old Nov 22, 2011 | 11:55 AM
frenchsquared's Avatar
frenchsquared
jb weld, make a two part epoxy. It should hold.
Rough up the paint first.
Old Nov 22, 2011 | 12:07 PM
427Z0SX's Avatar
427Z0SX
icanski: thanks for the tip. I thought Liquid Nails would be good enough. Also should've roughened up the surface too.
Turbo: I don't want to glue the board directly to the floor. My plan is to have the bolts stick up through the carpet, and the board will be secured to those bolts.
Thrash: I went looking for them "elevator" bolts, guy at Lowes said they didn'tcarry those, so I found something else similar. Head diameter is not 1", that's why I got 4 of 'em.
Old Nov 22, 2011 | 02:33 PM
Thrash's Avatar
Thrash
I got them at ACE hardware and will definitely need to use 4. Try another hardware store (ACE, TrueValue, H-Despot or get 'em online). But using the best epoxy possible may be all you need ... good luck ...
Old Nov 22, 2011 | 04:26 PM
markcz's Avatar
markcz
epoxy
Old Nov 22, 2011 | 05:01 PM
427Z0SX's Avatar
427Z0SX
The bolts are done, rock solid after 20 minutes. Sanded the surface, and Loctite Epoxy Plastic Bonder.
Thanks all!
Old Dec 24, 2011 | 04:54 PM
spankdxm's Avatar
spankdxm
Its amazing to me that liquid nail didnt work. I used to bond wood to smooth cement and I would have to beat it with a maul if a design change was made. It has to be a bad tube and the temp
Old Dec 25, 2011 | 09:40 AM
bass mechanic's Avatar
bass mechanic
just a suggestion, if your going to mount the amp behind the pass seat like this you might consider moving it all the way down to the floor..
usually when someone sits in the seat and have any recline to the seat back there will be quite a bit more room at the bottom. the backs of the seats usually rest on the top part of the area where that amp will be mounted.
also its a lot harder to see the amps if they are located lower on that wall.
Old Dec 26, 2011 | 05:58 PM
Thrash's Avatar
Thrash
I have to say I have been disappointed any time I ever used Liquid-Fails for anything. It barely hardens, if it does takes days and then it is brittle, only good for something light. Epoxy has never let me down though
To OK, so Liquid Nails doesn't work, now what?
