Sponsored by: Innova
Reverse lamp wires: where are they?
Old Nov 22, 2011 | 03:10 PM
427Z0SX's Avatar
427Z0SX
Default Reverse lamp wires: where are they?
Are they in either of these photos? Cubby in pix is driver side. I looked under the rear valance and saw the wires coming from the light bulb, but couldn't see where they enter the hatch. I need to tap into them for my rear view camera install. Thanks,
Old Nov 22, 2011 | 04:06 PM
markcz's Avatar
markcz
Post #2 of this thread or drill a small hole in the rear wall and run a wire to the reverse lights.
Old Nov 23, 2011 | 01:46 AM
427Z0SX's Avatar
427Z0SX
Thanks Mark,
I ended up removing the tail lights, saw a bunch of different wires taped together, I had to remove the wrapping tape, separated them one by one, and narrowed down to the 2 wires that run to the reverse lights. Hopefully I spliced into the correct wires!
Old Nov 23, 2011 | 09:21 AM
CGZO6's Avatar
CGZO6
There is a wire coming out of the BCM in the pass footwell that you can tap into for the reverse turn-on signal for the HU. If your looking for power for the cam, the reverse light + in the back is best (unless you have to run the cam wiring to the fromt anyway). I tapped into the BCM reverse turn on signal and wired a switch with a diode so that I could turn on the reverse cam at will (it still comes on when in reverse as well).
Old Nov 23, 2011 | 12:20 PM
427Z0SX's Avatar
427Z0SX
Thanks, I tapped into the reverse light wires for everything, camera and HU.
Old Mar 18, 2012 | 12:59 AM
c6reaperx's Avatar
c6reaperx
c6reaperx
Default wires
What color wires did you attach to for the camera power?
Old Mar 18, 2012 | 10:30 AM
markcz's Avatar
markcz
In C6 just about all exterior lights have a black wire as the ground. +12v to reverse lights should be light green.
If you ever want to look at reverse camera while driving forward you need to power it from switched wire that fires up radio, then just use reverse signal as trigger to HU.
Old Mar 18, 2012 | 02:01 PM
CGZO6's Avatar
CGZO6
I used the light green wire to power the camera and activate HU, then I added a switch to turn on reverse cam at will. When I used the switch to turn on reverse cam and activate HU, my reverse lights would also come on. I solved the issue with a diode so the BCM would not "see" the power going to the camera and not turn on the reverse lights (reverse gear still works normally at the HU and reverse lights).
Old May 22, 2012 | 11:53 PM
kocujeff's Avatar
kocujeff
6th Gear
Do you happen to have a picture of the wire from the BCM that I can tap into to tell my Pioneer HU to go to the reverse camera? I bought a wireless backup camera from China and this way I don't have to run any wiring from back to front at all..
Jeff
Old May 22, 2012 | 11:58 PM
markcz's Avatar
markcz
Jeff
Yep
To Reverse lamp wires: where are they?
