So I bought this kit but after I finished wiring new deck. I unplugged original head set but had to extra cables left over I tried using cables from kit but they didn't work help I would post pictures but I'm on my cell any and all help would be great thanks
Red yellow black from xsvi to same on radio for power
Blue or blue/white 'amp trigger' from radio to blue/white on xsvi
Match speaker wire output colors between both, plug it in and it should work
Check pots on xsvi to verify they're turned up enough
So the black box in the metra kit that say input output is not used?
I wired everything except for black box there are no wires in kit that hook up into it. I was also left with 2 unusable cords from oem area that were connected to bose unit
you really bought the wrong harness
The xsvi is known for issue
Dont be surprised if you have a dead battery some morning as your stereo wont shut off and it will run your battery dead
yea you keep RAP with this unit but your going to have issues
the pac roem-vet1 is the best harness to use for your car.
