Sponsored by: Innova
Reverse camera
Old Nov 25, 2011 | 06:18 PM
BigRobDsp's Avatar
BigRobDsp
Default Reverse camera
Does anyone know if you can use any reverse camera with the kenwood 418 hu or if you have to use the one that kenwood sells for $200? The universal ones look th be $30 and All seem to connect with a standard a/v video cable.
Old Nov 25, 2011 | 08:19 PM
Gadget01's Avatar
Gadget01
According to page 5 in the installation section of the owner's manual:
http://a248.e.akamai.net/pix.crutchf.../113DDX318.PDF,
the rear camera input is a standard composite video-in, so any composite video source will work.
I have installed the Kenwood backup camera on a van and it works very well. A $30 universal unit will also work, but compare the specifications to reputable name-brand units before you buy so as to avoid wasting your time/money on too cheap of a unit. If you shop around, you can find a reputable name-brand model for around $100.
Old Nov 25, 2011 | 08:49 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
Another thing to determine is, does the Kenwood head unit reverse the image or does it require that the camera puts out a reversed image.
Most backup cams that I've checked have a reversed image output. If the HU does it, then you have a lot more cam options.
One of the better looking installs I've seen posted here used a BMW X5 cam, mounted above the plate, near the trunk/hatch release button.
Old Nov 25, 2011 | 09:50 PM
markcz's Avatar
markcz
Google LP-1CA backup camera
Old Nov 26, 2011 | 08:46 AM
Rbohno's Avatar
Rbohno
Hey Mark,
Will this backup camera work with my x930bt?
Richard
Old Nov 26, 2011 | 08:20 PM
markcz's Avatar
markcz
It works great with my x920
Old Nov 27, 2011 | 12:41 AM
VerTigo456's Avatar
VerTigo456
St. Jude Donor '08
To Reverse camera
