Sponsored by: Innova
Back up camera install on AVIC x930bt
Old Dec 8, 2011 | 03:30 PM
wally2004's Avatar
wally2004
St. Jude Donor '11
Default Back up camera install on AVIC x930bt
On 2004 C5 A4. I know i am supposed to wire the violet/white wire to the wire that changes voltage on the switch at the shifter. There is a connector with 4 wires toward the front of the shifter. Colors gray, black, green/wht and orange. Can someone tell me if one of these wires is the correct wire? Left my meter at the office and don't want to drive back to get it with wires hanging out everywhere! Tried search and didn't dig up answer. Thanks
Old Dec 8, 2011 | 04:00 PM
markcz's Avatar
markcz
AFAIK there isn't a reverse signal inside the cabin of a C5, you need to run the signal wire back to the reverse lights when you run the video cable. Connect your purple wire to the light green wire at one of the reverse lights.
Old Dec 8, 2011 | 04:17 PM
wally2004's Avatar
wally2004
St. Jude Donor '11
Thanks Mark. I didn't think it would be as easy as a connector right on top inside where it is WARM!
To Back up camera install on AVIC x930bt
