Sponsored by: Innova
C6 Nav Radio Removal
Old Dec 13, 2011 | 05:08 PM
Thmprr's Avatar
Thmprr
Default C6 Nav Radio Removal
Hi
I need to gain access to the rear of the Audio unit, I have the Nav option single CD in a C6 2006. I need to do this to install a FM frequency extender between the aerial input and the audio units socket. This is because we have even number FM steps such as 99.2 instead of 99.1, so there is an extender that steps the frequency out by 0.1mHz. This is powered from the audio power feed, and must be powered up when the units on and not when off, (I have had some feedback from other NZ's who have had theirs installed by installers and suffered discharged batteries).
Old Dec 13, 2011 | 09:24 PM
markcz's Avatar
markcz
Dash removal is posted, a search should find it.
You can tap the white wire at B3 of the big plug behind the radio as your + power source. Schematics are HERE if you need them.
You'll most likely need to get adapters for the gizmo you have so it will fit in the GM antenna line. GM uses a smaller than standard plug for it's antennas. Google 'gm antenna adapter' and you should get results. You'd need two, one M-F and one F-M.
Old Dec 13, 2011 | 09:49 PM
Thmprr's Avatar
Thmprr
Thanks, many New Zealand C6 owners will be interested, I'm sure.
Old Dec 14, 2011 | 05:12 PM
Thmprr's Avatar
Thmprr
Can you tell me which type of plug is correct, this one
or this
Old Dec 14, 2011 | 07:01 PM
markcz's Avatar
markcz
The bottom one.
The Metra 40-GM30 Kit would be exactly what you need in one package
To C6 Nav Radio Removal
