Sponsored by: Innova
C6 Pasenger side cubby
Old Dec 21, 2011 | 04:01 PM
lionelc5's Avatar
lionelc5
Default C6 Pasenger side cubby
I have a 2008 C6 and I am in the process of adding a sub in the passanger cubby. But under the carpet in the cubby is a module.
I was told it was for onstar, but when I unpug it the car will not start and a message about ABS or anti locking braking system pops up.
There are two plugs on the top of the box that look similar to a coax plug, but one is slightly smaller. Are these plugs for OnStar? The car will run with out them, but there are 3 other multi pin plugs that have to be pluged in to run.
I am going to relocat the module, but is there anyone with some insite into what all the module controls and what plugs do and do not need to be extended? I dont care about the OnStar at all.
Sincerly,
LionelC
Old Dec 21, 2011 | 04:24 PM
EVRose's Avatar
EVRose
That is the VCIM (Vehicle Communication Interface Module). Look at Marks response to my question in THIS thread.
Old Dec 21, 2011 | 06:09 PM
lionelc5's Avatar
lionelc5
Thank you very much! So the antenna connections are for GPS and OnStar, both of witch I dont need so I dont have to connect them.
The other multi pin plugs will be easy to extend with a little wire and soldering.
Gotta love the CF, it seams that someone has always had a problem, and found the solution before and saves everyone else alot of trouble by posting here.
Thanks again,
Lionel
To C6 Pasenger side cubby
