Sponsored by: Innova
SYS light
Old May 10, 2002 | 12:30 AM
Jasin9687's Avatar
Jasin9687
Default SYS light
ok, now I was driving my 96 lt4 that I had just put a headunit in and the "sys" light in my car flashes, i read it was an electrical problem... could this be because of the stereo????
Old May 10, 2002 | 01:39 AM
Marcho Polo's Avatar
Marcho Polo
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
Default Re: SYS light (Jasin9687)
If "SYS" is displayed in the LCD section of the instrument panel cluster after the customer installs a new stereo, he will need to do the following:
1. Buy (2) 1 kilo-ohm 1/2 Watt resistors. [Radio Shack part # 271-023. They sell them as a 2-pack for 29 cents.]
2. Disconnect the negative battery cable.
3. Remove the receiver.
4. Connect one end of both resistors to ignition power. (Yellow wire in the car.)
5. Connect the other end of one resistor to the purple/white wire in the car.
6. Connect the other end of the second resistor to the grey/black wire in the car.
7. Cover all connections and completely cover the resistors.
8. Reconnect the negative battery cable.
:cheers:
Old May 13, 2002 | 01:25 PM
Jasin9687's Avatar
Jasin9687
Default Re: SYS light (Marcho Polo)
and when I do all that it should turn off the sys light automatically? if so sounds damn good 2 me :cheers:
Old May 13, 2002 | 03:34 PM
Marcho Polo
Former Moderator
I believe the light will go away, but until you clear the codes, there will be an error stored in the history....
Old May 14, 2002 | 10:52 AM
novi408's Avatar
novi408
I did this when I recently installed my head unit and it worked. It really is simple, just put the 2 resistors in, cover everything up, and put the dash back together. I did have the SYS light on for a day or so while waiting for my head unit, but as soon as I installed the resistors it went away. I don't know if there is a code stored, have to check that out today.
Old May 14, 2002 | 01:03 PM
Marcho Polo
Former Moderator
Default Re: SYS light (novi408)
Oh, one other thing..... this problem only occurs for people with manual a/c controls I think..... you guys getting this code, is that what you have? Or do you have auto climate control?
Old May 14, 2002 | 01:55 PM
novi408's Avatar
novi408
I have manual AC controls and got the SYS code.
Old May 15, 2002 | 02:25 AM
Jasin9687's Avatar
Jasin9687
same here.... Ill try it in a day or so my mom is going in for surgery 2morrow :(
To SYS light
