Sponsored by: Innova
Removing console with automatic tranny: need help
Old Dec 29, 2011 | 10:33 PM
Denny79's Avatar
Denny79
Default Removing console with automatic tranny: need help
Hi,
I am removing the console and I have automatic transmission. It seems like the transmission lever is preventing me from removing the console (it is loose but does not come out because of the lever). I do not want to start the engine since the battery is out and a lot of electrical stuff is disconnected and seats are removed.
Is there any way to remove the console without putting the shift lever to Neutral? Is there a way to put the lever to Neutral without starting the engine?
Old Dec 29, 2011 | 10:59 PM
EVRose's Avatar
EVRose
You won't be able to move the shifter without power and I'm pretty sure you won't be able to get the console off without moving it. Put the battery back in and put it in accessory mode and you'll be able to move the shifter without starting it.
Old Dec 30, 2011 | 12:54 AM
Denny79's Avatar
Denny79
Thank you. I will try it.
Old Dec 30, 2011 | 08:28 AM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
You need to have the shifter back as far as it will go (S).
Having it up in Park won't work. Your going to need some battery voltage to get it out of Park
Old Dec 30, 2011 | 12:14 PM
Denny79's Avatar
Denny79
Thanks guys. I put it in acc mode and it worked!
To Removing console with automatic tranny: need help
