Sponsored by: Innova
Confused about using C5 aux input for XM
Old Jan 2, 2012 | 08:53 PM
Z06seal's Avatar
Z06seal
Default Confused about using C5 aux input for XM
Ok, so I got my XM setup and using the FM transmitter option now, which is ok. but I want hardwired sound.
I looked at the FAQ here and it looks like 2 pieces are needed. I don't understand why..
Correct me if I'm wrong
I get the PIE GM10-AUX 1995-2004 GM 10-pin Auxiliary Input Converter and plug that into the back of my headunit. then I plug the aux cable into the box...
Here is where I'm confused...
the FAQ says -
Parts needed:
XM Commander
Factory CD Changer Harness (purchased mine from Litewarehouse: $68.99)
PIE Auxiliary Input Connector, GM10-AUX (purchased mine from Litewarehouse: $66.99)
Short RCA cable
Double sided tape
3 Electrical Butt Connectors
ok, What is the one highligthed in red? Why do I need a cd changer harness? isn't there a slot on the back of the OEM headunit that the GM10-AUX just plugs into?
and lastly, this is where I just got confused while trying to get a picture of a C5 radio back...
I see a little aux input on the back there. is that a regular 3.5mm aux jack? I can't tell... what's all this hassle if there is a little slot back there?
Old Jan 2, 2012 | 09:28 PM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
This is what you need
http://shop.doubledmods.com/ZUNE-C5-...?categoryId=-1
This is install intructions
info shows the PXDP ipod version but same install info
http://www.doubledmods.com/uploads/i...and_PXHGM4.pdf
Sold hundreds of these with no issues
Old Jan 2, 2012 | 11:05 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
i dont know what picture you have etc but there is no 3.5mm jack on the back of a c5 radio factory
Old Jan 3, 2012 | 05:21 PM
Z06seal's Avatar
Z06seal
Thank you!!! I'll be getting this very soon!
To Confused about using C5 aux input for XM
