Sponsored by: Innova
Backup Camera Wire Routing Help?
Old Feb 2, 2012 | 01:46 PM
kags1969's Avatar
kags1969
Default Backup Camera Wire Routing Help?
I have a Pioneer 920bt installed in my 2010 Coupe and am adding a rear view camera. I have searched but haven't found specific advice about routing of the camera wires.... I am using a license plate frame type of camera and just wondering what is the easiest route to the stereo?
Thanks,
Kags
Old Feb 2, 2012 | 04:29 PM
WAwatchnut's Avatar
WAwatchnut
Since you have to remove the center console anyway, you could run the wire along either side of the center tunnel. You can then pass it under the carpet behind the seats. The carpet in the hatch area lifts up, and you'll need to remove the panel in the very back of the hatch area. Not sure where to fish a wire through the body panel, but you should be able to find somewhere pretty easily.
Old Feb 2, 2012 | 06:50 PM
markcz's Avatar
markcz
What I do....
Once at the back wall just drill a hole. Make it just big enough for the smallest plug on the camera wires, then seal it with duct tape.
To Backup Camera Wire Routing Help?
