Sponsored by: Innova
Finished my upgrade
Old Feb 12, 2012 | 12:11 AM
X-Ravin's Avatar
X-Ravin
Default Finished my upgrade
Tweeter mounting, much better than stock location.
Everything mounted and ready to install.
Power wire run.
Mocking up wiring.
First power on test.
Speakers and new 16ga wiring installed.
Messy! Luckily hidden under the sub.
Everything installed.
Slight depth issue with mounting the head unit, had to cut out the mounting tab to fit.
HUMount kit.
Custom cover with integrated sub-grill crafted by NVTHIS. Good for security.
Very happy with it. Had to get used to a 10" sub on only a couple hundred watts, my old car had 2 12"s at 1000W. Tweeters needed to be attenuated about 3db.
Old Feb 12, 2012 | 09:59 AM
Thrash's Avatar
Thrash
Great job on the pillar-tweets! But man, you gots to clean up that wiring!
Old Feb 12, 2012 | 10:33 AM
markcz's Avatar
markcz
Old Feb 12, 2012 | 11:45 AM
BACNBLK's Avatar
BACNBLK
Nice job, hope it sounds as good as it looks!
Where did you get the HU Mount Face Plate,and is it back lit?
Old Feb 13, 2012 | 10:11 AM
X-Ravin's Avatar
X-Ravin
http://maptechenterprises.com/storef...53b7c2e0b0e918
Mine is not, but it is an option with lots of color choices. I might mod mine in the future with some LEDs.
To Finished my upgrade
