Sponsored by: Innova
tweeter freq adjustment help please.
Old Feb 13, 2012 | 05:50 PM
Kensmith's Avatar
Kensmith
Default tweeter freq adjustment help please.
I have upgraded component door speakers with 1" tweeters. They sound a little overpowering with the highs. How can I adjust them to mellow them out a little. I have a Diamond Audio D6 5.1 amp with high pass filters and freq adjustments. Also high pass bypass switch. Where do I start?
Thanks!
Old Feb 13, 2012 | 06:09 PM
markcz's Avatar
markcz
Model # of the component set? Does it have an adjustment switch on the crossover?
Old Feb 13, 2012 | 06:37 PM
Kensmith's Avatar
Kensmith
Hybrid Audio Technologies Clarus C61-2 6.5" and 1" components
I don't believe the crossovers have switches.
Old Feb 13, 2012 | 07:44 PM
knewblewkorvette's Avatar
knewblewkorvette
From their website:
An additional Clarus-level enhancement is the inclusion of two-way passive crossovers containing
the same crossover and tweeter attenuation topology as Clarus, all encased in a display-ready
housing with gold-plated screw terminals
Old Feb 13, 2012 | 08:16 PM
Kensmith's Avatar
Kensmith
Originally Posted by knewblewkorvette
From their website:
That means nothing to me.
Old Feb 13, 2012 | 08:19 PM
knewblewkorvette
From their website:
Seems like your crossover do have tweeter adjustments.
Old Feb 13, 2012 | 08:33 PM
Kensmith's Avatar
Kensmith
If they do, I never saw any switches, screws, *****, or other way to adjust them. But then, I wasn't looking for any adjusting when installed. I figured the amp makes the adjustments or filters. When it comes to this kind of stuff, I'm the village idiot.
Old Feb 13, 2012 | 10:48 PM
kedar's Avatar
kedar
St. Jude Donor '12
Go here: http://www.hybrid-audio.com.ar/docs/Legatia%20L2x.pdf
Read the end of page two and into page three. Looks like you have to do something on the circuit board.
Old Feb 14, 2012 | 12:02 AM
Kale's Avatar
Kale
It's more than likely a peak around 3khz in your car rather than the tweeters being too loud in general. Do you have EQ?
Also, try swapping the wiring on the tweeters too... old trick.
Anyway, thta PDF has some great high resolution pictures that show absolutely nothing useful. Sometimes tweeters have a +3 0 -3 terminal, and you just wire one side to it.
Being that I see a group of three red terminals there, I'd bet this is the case.
Sometimes tweeters are blamed for this issue and aren't the root cause.
Old Feb 14, 2012 | 12:25 PM
Kensmith's Avatar
Kensmith
So nothing I can do at the amp with Highpass filter? I really don't want to take the door panels off to see what if anything can be changed on the crossovers. Guess I could turn down the treble on the head unit and see if that helps. The tweeters are nice and clear, just to me I like more midrange.
Old Feb 14, 2012 | 05:12 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
turn attenuation down on xovers is what i would do
Old Feb 14, 2012 | 05:29 PM
Kensmith's Avatar
Kensmith
Will try that, they sound much better when I turned down the treble on the head unit to just under the half way mark. My son likes the sound out of the tweeter but for some reason my 62 year old ears likes a little more mellow.
Old Feb 14, 2012 | 05:51 PM
Kale's Avatar
Kale
How much EQ flexibility do you have? You have a sub, right?
Where are your crossovers set at?
I'd be willing to take a listen to it one of these days. My laptop I use for audio testing only has a 10 minute battery on it though.
Old Feb 14, 2012 | 09:15 PM
Kensmith's Avatar
Kensmith
No EQ stock head unit, amp is Diamond Audio D6 5.2. I have 2 subs. Amp has Highpass and Lowpass and crossovers on the amp are fixed at 80hz which can be defeated by a switch. Hope this helps. I don't know what the speakers components are set at but whatever the factory set them at. They were installed by a professional stereo installer so I don't have that information.
Old Feb 15, 2012 | 04:14 AM
chevyc6z51's Avatar
chevyc6z51
this is great info , and I THINK HE IS RIGHT..Try mids on head unit
Old Feb 15, 2012 | 11:47 AM
Kensmith's Avatar
Kensmith
Turn up mids on head unit to overpower tweeters?
Old Feb 15, 2012 | 02:24 PM
chevyc6z51's Avatar
chevyc6z51
Try turning them down not up
Old Feb 15, 2012 | 02:39 PM
Kensmith's Avatar
Kensmith
Ok, thanks.
To tweeter freq adjustment help please.
