I am mounting a rear sub-woofer an amp in my 06Z with Bose system. I am not a stereo expert by far but I am wondering is there a way to use a crossover or anything else for my door mounted 10s to make them more of a mid range speaker?
Ditch the door speakers and buy some nice components for the doors.
Those tens are not worth messing with, in the trash is the best place for them, sad but true.
If you want to do this right get some Alumalite baffles, filler panels, aluminum channels, RAAMmat and Ensolite and deaden the car right, put in a set of good components(great ones do not have to cost a fortune), run a good little amp on them.....sure it costs a bit but the end results is a transformed car, they way they should come from GM
If you want some help setting all this up, I offer it all, full factory warranty on my Arc Audio based ultra low weight, stealthy, dang fine system packages at a great price!
