audio upgrade questions
I want to upgrade my factory Blose nav system with a modest system. I will start with a new double DIN HU...probably something from Alpine or Kenwood Exelon.. mainly for better sound quality, complete iPod/Pandora interface/control and Bluetooth. don't really care about nav that much.
next will be speakers (and here's where the questions start). I have read a couple threads of some who have put JL 8s and even MBQuart shallow 10s in the doors, but can't find them again to see how they ended up sounding. I'm not against going with good components, but as I autox and HPDE my car regularly, not having a sub/amps in the hatch would be a big benefit. unless they were very easily removable-but even then, doing this almost every weekend would get old. so, I'm looking for decent bass without having to add a sub box/ rear mounted amp.
which brings me to the amp question- other than the Arc Audio, are there any good amps that will fit in the factory Blose compartment in the foot well? I have zero experience with this brand, and will not buy anything without hearing it first or knowing someone who has them. I know, I know, just how I am
comments? ideas? rude statements?
Haven't used the Arc minis, but it's hard to not believe the great rep they have.
I do some eventing also and wanted to save weight. Put the stealth box in the back with a sub and just pop it out on event days. I did this for years with my firebird, takes less than 1 min to remove/install. Then use the Arc or Kenwood 5S amp mounted in the rear. If you put some nice 6" components in the door the weight will almost be a wash if you pull the sub box.
I wouldn’t recommend it for reasons I posted in the novel of a thread I started today called “subwoofer adventures (c6 convertible)".
However, I’ve been very impressed with the Arc Audio 125.4 mini amp, the sound quality is good and it's powerful despite what its size may suggest.
Examples: Posting a new thread in a few minutes, been a busy day, sold another system and shipped a ton, really, of deadening products today
Rick
801-829-4997
one more question-where is everyone getting the adapter plates for the door speakers? haven't found anyone selling them outright yet.
Many Vettes are out there with two KS Mini amps in the stock C6 location.
Rick
801-829-4997
what all are you running now? nice sub box btw!
Rick
801-829-4997
thanks again for all the input!
I tried the subless system at first, Morel 9's, not enough bass, far to many resonance issues even after massively modifying the doors, not worth it.
I also have the lightest weight C6 sub enclosure on the market, full fiberglass, hand laid, with the Arc 10 sub list is $599, intro sale for $449 shipped in cont US! I need to post a thread on it sometime
Rick
What he is saying in laymen terms …. things inside of the doors and door panels will buzz and make all kind of weird noises as volume increases. This was also my experience, and I also agree its not worth the work for what results you get.
Especially with the “drop in” subwoofer enclosures that are available for the hard top C6 ..... I’m not as impressed with the “drop in” subwoofer enclosures available for the C6 convertible … but that is just my opinion based on what “I” wanted (avoid using the trunk)
As far as my statement “they sounded good at modest levels” ....... I could turn it up slightly louder than the stock Bose setup … but not that much louder before experiencing resonance problems and the subs bottoming out (but I blaim the "bottoming out" problem on using a non-free-air sub).
Right now (until I change it) I’m using the same amp (2 channels of the mini Arc Audio at a mono 4 ohm load) with the same subwoofers (MB quart) in the new box I built ….and its a night and day difference
The easiest way to describe the point I’m trying to make is:
I’ve heard crappy speakers sound good in a well built enclosure (box), but I’ve never heard good speakers sound good in a crappy enclosure.
In my door sub experiment, I put mediocre speakers (new era MB Quarts) in a really crappy enclosure (the doors) and I wasn’t really surprised in the results.
Have you tried your Arc 10 subs in an enclosure in around .5 cubic foot?
“Or” have any suggestions for a good 4 ohm 10 that will work in a .5 sealed enclosure … I want to add a mini 500.1 Arc amp … but it looks like the 500.1 runs best at a mono 2 ohm load?
The subs I currently have are 4 ohm DVC and I would want to upgraded them anyway if I was to run a Arc 500.1
I usually have both the D2 and D4 subs in stock and 500.1 amps always in stock unless like now just sold the last one but more should be here tomorrow.
The XDi amps are tempting for watt per dollar and are the latest and greatest of the chip amps but they just do not quite sound as good as an AB or as in the KS Mini amp, Class H (AB amp with an analog switching power supply) I have tried many D class amps and always stick with AB or H but I keep hoping one day Class D will do it for me.
BUT, I play only really high quality recordings where amp choice is more critical, I am starting to download audiophile tracks so I can just pick the music I want, not the whole album, etc but it is pretty expensive(though much cheaper than some of the actual disks, I have one that cost me $100 but it is the absolute best test disk I have ever heard, I use it all the time for demo use, blows peoples minds
If you mostly play average recordings from an Iphone, etc, not quite so important, I offer the D class amps, just do not stock them and only sold a few ever as I love those little KS Mini amps, they are incredible for their size
I am here to answer your questions whenever you want to call me.
Rick
801-829-4997
