Sponsored by: Innova
Amp installation question
Old Mar 9, 2012 | 04:27 PM
7LitreC5's Avatar
7LitreC5
Default Amp installation question
I am installing an amp in my C5. Do I need to hook the amp power directly to the battery terminal or can I hook it to the stud that is in the underhood fuse box? If it needs to go to the battery I'll need some sort of extender/adaptor since it is a side terminal battery.
Old Mar 9, 2012 | 04:35 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
gm sidepost battery terminal adapter will do it
what size is the amp
Old Mar 9, 2012 | 04:43 PM
7LitreC5's Avatar
7LitreC5
It is a Kenwood Excelon XR-5s 5 channel mini amp.
Old Mar 9, 2012 | 05:32 PM
pentavolvo's Avatar
pentavolvo
do a sidepost battery terminal adapter, most autoparts stores cary them
Old Mar 9, 2012 | 06:39 PM
7LitreC5's Avatar
7LitreC5
Thanks! I'll pick one up.
Old Mar 9, 2012 | 06:41 PM
b.lee's Avatar
b.lee
Connected mine to the positive stud in the underhood fuse box
Works perfect.
Old Mar 10, 2012 | 06:57 PM
TrueBlueCoupe's Avatar
TrueBlueCoupe
Same amp, I connect mine to the post on the side of the fuse box. I have the top post setup on my battery
To Amp installation question
