Sponsored by: Innova
6 disc changers
Old Mar 10, 2012 | 08:56 PM
dklowrider's Avatar
dklowrider
Default 6 disc changers
i can't seem to find the right info so here are some simple questions.
are all factory in dash C6 6 disc changers units bose?
if so, then i assume none should work in a non-bose '07. is that just due to amp/power delivery issues?
if they are not all bose, how do you tell the difference between the two?
absolute facts will be greatly appreciated. i've already been through all the "it should work" kind of stuff.
thanks in advance for good knowledgeable answers.
Old Mar 10, 2012 | 09:40 PM
crazyeddie's Avatar
crazyeddie
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13
I bought a gently used 2009 3lt back in June. It had the stock 6 disk changer and I had a Pioneer AVIC Z130 NAV System installed. I checked out the unit that I took out and it is a Denso unit. The speakers are Blose. Hope this helps, I thought the head unit was Blose---e
Old Mar 10, 2012 | 11:15 PM
dklowrider's Avatar
dklowrider
that's the kind of thing i've been running into. i keep thinking the unit should say bose somewhere on it. maybe it's only the speakers that are bose and the same headunit is used. or maybe the output is different between the two but they look the same.
or something.
Old Mar 11, 2012 | 11:58 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
both headunit bose and non bose output the same thing. both bose and non bose cars have seperate amplifiers
Old Mar 11, 2012 | 01:43 PM
dklowrider's Avatar
dklowrider
so am i correct from that info that i can use any 6 disc unit in my non-bose car and it will work fine?
Old Mar 11, 2012 | 07:20 PM
markcz's Avatar
markcz
I haven't personally done it, but it SHOULD work
Old Mar 11, 2012 | 08:39 PM
dklowrider's Avatar
dklowrider
there's that word 'should' again.
maybe i'm just looking for Jesus himself to knock on my door and say "yes my son it will work"
To 6 disc changers
