Sponsored by: Innova
Need wiring color codes etc....
Old May 17, 2002 | 10:52 AM
95DropTop's Avatar
95DropTop
Default Need wiring color codes etc....
I am about to install a new head unit, speaker, etc and also an alarm in my 95 and need all the correct wire codes and how to disable the factory alarm, etc. I also need to know of anything special I should be looking for or should be careful not to do. Thanks for the help :cheers:
Old May 17, 2002 | 02:10 PM
92TripleBlack's Avatar
92TripleBlack
Default Re: Need wiring color codes etc.... (95DropTop)
Get a wiring harness for the deck. You won't need to cut the wires and they will be labeled. Run new speaker wires from your deck or amps. The stock stuff is crappy low strand 16 gauge wire. Use high strand 12 or 14 gauge wire. I prefer 12 as it works better with amps. Most alarm companies have a companion installation brochure that tells you how to integrate the alarm with the stock system. If you don't have one, check the clifford alarms web-site. They have this posted in their manuals area and you should be able to adapt the information to your alarm.
Old May 18, 2002 | 12:08 AM
DanC5's Avatar
DanC5
Default Re: Need wiring color codes etc.... (92TripleBlack)
Where do you get the right wiring harness? GM parts or other?
Old May 21, 2002 | 01:57 PM
95DropTop's Avatar
95DropTop
I don't want to adapt to the factory alarm, I want to bybass it. Basically I just want it turned off. Any ideas??
Old May 23, 2002 | 04:48 PM
95DropTop's Avatar
95DropTop
TTT anybody??
Old May 24, 2002 | 12:16 AM
blk_c4's Avatar
blk_c4
You can get everything you need from http://www.corvetteradios.com. He's a nice guy, very helpful and ships fast. I did the same thing. Good Luck.
:seeya
To Need wiring color codes etc....
