Sponsored by: Innova
help with 10" sub and 1 cu.ft. box
Old May 17, 2002 | 04:35 PM
The Edge's Avatar
The Edge
Cruise-In III Veteran
Default help with 10" sub and 1 cu.ft. box
I've got a 1 cu. ft. box I want to use. What sub would give me a good sound? Most of the 10" subs I have found are recommended to be used with a .5 to .75 cu. ft. enclosure. A 12" sub is too large for my box.
Old May 23, 2002 | 04:14 PM
gcrouse's Avatar
gcrouse
Default Re: help with 10" sub and 1 cu.ft. box (edge99hardtop)
I assume you meant a sealed box (since vented are larger)? If sealed, 1 cu ft is on the large side for a 10; but all you'll really do is reduce the system Q (rolloff). Sealed boxes aren't nearly as fussy and many folks like the sound of low-Q systems for tight, accurate bass. I've used JL Audio 10w0 and 10w3 successfully in 1 cu ft; just glancing at my Crutchfield catalog here's a couple other 10's that should work:
Kicker Comp, CompVR
Rockford HE, HE2
Polk GXR
Or if you have a particular driver you like with smaller box requirements, it's easy to reduce internal volume. Just add anything that displaces air; glue in wood blocks for additional bracing, can of Spam, etc.
Since you have the volume, you might look for a sub that moves air and takes advantage of your larger box- JL 10w7, Eclipse Titanium, etc. Here's a couple favorites I've been looking at:
http://http://www.subwoofers.com/Mob...ivers/sv10.asp
http://www.partsexpress.com/pe/pshow...number=295-412
[Modified by gcrouse, 11:34 PM 5/23/2002]
Old May 23, 2002 | 06:14 PM
lotzahp's Avatar
lotzahp
Default Re: help with 10" sub and 1 cu.ft. box (gcrouse)
I run 12" Kicker Comp subs in the recommended sealed enclosure, and I really like them. The 10" would be great for a box less than 1cu/ft.
Old May 27, 2002 | 04:16 PM
JoeyG's Avatar
JoeyG
Cruise-In IV Veteran
Is it built down into the lower well. For the cheap suggestion, spacer plates maybe added to remove interior volume. How wide and deep is the box top plate? Also what is the thickness of the top plate?
Side note: Thanks for the cab rides at the cruise Inn! :cheers:
Old May 27, 2002 | 06:32 PM
flannel_man's Avatar
flannel_man
Cruise-In VI Veteran
I use Kicker Comp. VR's , howvwer most brands , such as Kicker , Alpine, and Kenwood tell you the recommended space for each line of subs. Check out their websites.
To help with 10" sub and 1 cu.ft. box
