Sponsored by: Innova
Front door tweeter wires
Old Apr 5, 2012 | 08:26 AM
xgto's Avatar
xgto
Default Front door tweeter wires
I'm adding some tweeters to the side windshield pillars. Where can i catch the left and right wires for the upper door speakers (mid range -tweeters), hopefully somewhere under the dash. need to know location and colors if possible.
thanks for any help on this.
Old Apr 5, 2012 | 09:24 AM
markcz's Avatar
markcz
C6 prints are HERE
The amp is next to the passenger floorboard fuse box, everything else is behind the radio.
IMO it would probably be easiest to just pop the door panels off and tap into the wires just before the speaker.
Old Apr 5, 2012 | 09:27 AM
xgto's Avatar
xgto
That means that I have to pull the door panels. the tweeters are going into the windshield pillars.
Old Apr 5, 2012 | 09:57 AM
Thrash's Avatar
Thrash
The wires for the door speakers go through the rubber accordion, so if you look up under the dash on both sides you can see where they are and tap into them. Not sure what colors are for what speaker, but should not be that hard to figure out ...
To Front door tweeter wires
