Sponsored by: Innova
Need Help ....
Old May 23, 2002 | 12:17 AM
thode's Avatar
thode
Default Need Help ....
I have a 1994 C4. I took the Gold Bose system out today. I have learned that the rear speaker are a 6in and the front I have no clue Has anyone changed out there system recently. Everone has 6x9 and 5.25 but I cannot figure out how to mount the 5.25 in the doors. My car has pod down on the lower part of the pillar just below the door. Is that where everone has mounted there speakers because there is no room on the door for a speaker that large. Any help would be great ...
:crazy:
Old May 23, 2002 | 01:14 AM
92TripleBlack's Avatar
92TripleBlack
Default Re: Need Help .... (thode)
6x9 rear. They should plug in the rear openings after you remove the bose. Front goes where the stock speakers are. Yes, in the floor pod. Door pannels are $500 each to replace if you cut them. Remove the entire rocker cover. The speaker grill is bolted to it from underneath. Its a few screws.
