Sponsored by: Innova
C5 Bose sound issue
Old Jun 10, 2012 | 11:24 PM
GS023's Avatar
GS023
Default C5 Bose sound issue
I am working on a 2000 coupe with Bose AM/FM/Cass/CD cahnger. I had the dash, radio, etc.. out to replace a/c actuator. Now radio has very low volume and a humming through the speakers. Humming continues a few seconds after radio is turned off. Reception seems to be fine.
Any suggestions?
Old Jun 11, 2012 | 12:10 AM
markcz's Avatar
markcz
Check fuses 24 & 28 in the footwell.
If both are good I'd pull radio out to make sure all plugs are in all the way and that none of the pins are bent (pins properly & fully inserted into plugs).
Is it the same on all sources (CD, tape, FM)?
Old Jun 11, 2012 | 06:28 AM
GS023's Avatar
GS023
Will check this.
Yes, all sources acting the same.
Old Jun 11, 2012 | 04:09 PM
GS023's Avatar
GS023
All pins, fuses, and CB's good. Looks like it's going to Dr. Don's.
To C5 Bose sound issue
