JL HD amp tuning question
I have the amp set to the High Pass filter for the components (channels 1 and 2) and I have it set to Low Pass for Channels 3 and 4.
My question is: Should I just turn off the filter for Channels 1 and 2, giving me a little bit better range? Wouldn't I get some of the lower frequencies from that mid-range component if I did this?
Both channels 1 and 2 and channels 3 and 4 are set to about 80 hz.
I have adjusted the input sensitivity on channels 3 and 4 twice and it seems like I either get no bass or too much bass. Is this old age or am I missing something?
Generally, having some sort of high pass on the mids is a good idea since it keeps them focused on playing notes that are actually possible for that size speaker. I would keep your crossover on, but perhaps play with the frequency setting. Don't be afraid to try a much lower crossover point, either. I run mine at ~65Hz between the sub and mids, but I have pretty healthy mids.
