Sponsored by: Innova
1993 passenger window
Old Jun 30, 2012 | 09:09 PM
pjgiantsfan's Avatar
pjgiantsfan
Default 1993 passenger window
I recently purchased a 1993. It has been performing great. Today I took it to work and on the way home the passenger window would not work. The drivers side is operational. I don't believe its the circuit breaker if one is working. Can anyone assist in troubleshooting?
Old Jul 1, 2012 | 01:08 PM
markcz's Avatar
markcz
I'm not sure if applies in a '93, but in C5 the motor brushes would sometimes get a layer of corrosion under them. Other than driving the car more often, the 'easy' fix was to hold down the window button while slamming the door several times. If you're lucky, and that's the problem, then the window will start to work after a few SLAMS
