Sponsored by: Innova
Replacing front speakers in C5 Coupe
Old May 31, 2002 | 02:52 PM
Michaeljh3's Avatar
Michaeljh3
Default Replacing front speakers in C5 Coupe
I'm aware that the doors on a C5 Coupe have a speaker and sub combination. Is the speaker located in the door, a full range speaker or some sort of mid range? Is it worth while to replace the front speakers, which I intend to drive with a separate amp and if so, which front speakers should I get? Also, I intend to keep the stock head unit and built in Bose subs. I have already replaced the rears with component speakers.
Old Jun 2, 2002 | 08:18 PM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Replacing front speakers in C5 Coupe (Michaeljh3)
8" sub and 3-1/2" mid/tweeter combination (think dual cone principles). If your going to apply any more power, or power from a seperate amplifier system, the factory Bose will not take a whole lot of increase. Also to still incorporate the factory speakers is more of a detailed wiring scheme than just running speaker wires to speaker plate connector. Thins to think about. :cheers:
