My first Mod...Curb Alert Mini install
I saw some videos of easy installs for the curb alert but I wanted mine installed with the wiring harness routing. I looked and found some photos of audio pics that showed the areas but nothing specifically for the curb alert install so I just wanted to post these pics for reference. After I got it done, it's pretty freaking easy to just route through the firewall vs around the door jamb and visible.
Anyway, heres the pics. Only thing to mention is to do it easy, take the battery out. I've got a C6. The wiring harness goes through an access hole right behind the battery. Easy, just cut the electrical tape, make a coat hanger fish hook to run the wire for the sensor (grease it up) and pull it through. I put the speaker up under the dash (mounted on the metal box in the pic, behind the dash cover). Tucked the wires and box up under the amp. Works fine, just make sure to adjust the sensor up front and tighten the bolt. Was a little loose on mine.
Anybody looking to add this great front end saver, they are on sale at Corvette Mods!
http://www.corvettemods.com/Corvette...s-_p_5631.html
