Sponsored by: Innova
04 Z06 Stereo Problem
Old Sep 22, 2012 | 03:25 AM
PBone's Avatar
PBone
Default 04 Z06 Stereo Problem
My brother also has a 2004 Z06 and is having some issues with his stereo.
This is a Non-CD stock headunit. The front speakers have no sound coming from them. The rears play some music, but it doesn't get any louder than about 10-15%. Would you think this is a headunit issue since it's related to the volume? Would he be able to pick up another stock headunit and the issue be fixed or do you think it's a speaker issue?
Old Sep 22, 2012 | 09:47 AM
markcz's Avatar
markcz
There are several possible causes, but the speakers wouldn't be on my list.
You say "non-CD", if that also means non-Bose then I'd put a good chunk of money on the radio itself being bad, but I thought all C5's came with Bose by '04.
If it is Bose, then it could be the radio (only amp in C5 is internal to the radio), or it could be the Bose processor, or possibly just that the radio isn't properly powering the processor.
C5 prints are HERE if you have a meter and are willing to poke around with it. My first check would be the dark green wire (circuit 145) for +12v when radio is on.
If it were me and I wasn't able to troubleshoot the wires, I'd prob find a cheap oem C5 radio and swap it out. If still available you can get one for free HERE
Old Sep 22, 2012 | 10:58 PM
PBone's Avatar
PBone
Thank you!!
Old Oct 7, 2012 | 04:02 AM
PBone's Avatar
PBone
So I think I discovered the problem.. Cannot believe we missed it.
The car does have the bose system, but has a non-bose headunit. Needless to say, we snagged a bose unit off ebay that should be here middle of the week.
Looks like the previous owner tried to make a few bucks before selling it.
Old Oct 7, 2012 | 10:53 AM
markcz's Avatar
markcz
I thought a non bose HU would still play through the four normal speakers in a bose equipped C5, the plug pins for them are the same.
If the new HU doesn't make it all better, you'll need to look in the doors to see if the speakers are there, and if they're plugged in.
If oem gear is removed it would be easiest (and prob cheapest) to put in a modest aftermarket setup.
Old Oct 17, 2012 | 11:10 PM
PBone's Avatar
PBone
Little update..
HU was replaced with a bose unit, same problem with the volume.
All 4 door speakers were replaced with aftermarket speakers, same problem..
bleh
Old Oct 18, 2012 | 07:54 PM
markcz's Avatar
markcz
Print out the C5 prints from post #2 and take them and the car to an audio shop (or just someone handy with a meter), it shouldn't take them an hour to find the problem.
To 04 Z06 Stereo Problem
