Defaults to Driver 2 C6
I have been just dealing with a problem and it is starting to get a little annoying. I have a 2007 convertible and I use only the key fob for driver 1. Whenever the car is off and I start it, the car defaults to driver 2's personal settings such as radio, hud, and seat settings. I have to manually hit driver 1 to get all my settings. I have looked in the personal preferences of the vehicle and do not see a setting that dictates the default. Does anyone have any ideas on what the problem is??
Thanks,
John
So, when you set stuff up for fob #1, those settings would match the settings of the fob stamped "2". So, if you carry the other fob, you should be set. The car has no idea what number is stamped into the case of the fob.
Just my $0.02. YMMV
