Sponsored by: Innova
C6 deadening questions
Old Oct 9, 2012 | 09:56 PM
newvetteguy9's Avatar
newvetteguy9
Default C6 deadening questions
Hey guys i'm looking for anyone that has gone through the process and what all material wise was used. I looked at the sticky but it doesn't list amounts. So lets here it What have you used?
Old Oct 10, 2012 | 02:41 PM
Thrash's Avatar
Thrash
On my Deadening Sticky above I explained everything ... but not the exact amounts, as they were all kits that came ready to be applied. The things I ordered that were not precut were the BXTII, Ensolite sheeting and the SD butyl rope, for which the supplier rec'd how much I needed, and I ordered extra. The supplier will suggest the amount needed when not in pre-cut form, just be sure to get 10-15% extra to cover your bases.
Good luck and take lots of photos and post what you do ...
Old Oct 10, 2012 | 07:32 PM
markcz's Avatar
markcz
Rick from RAAMaudio posted this info. In my car I went with 1.5 BXT and 6 yards of Ensolite, there was enough BXT to cover just about everything and I have a bit of Ensolite left over after 100% coverage
Old Oct 13, 2012 | 05:55 PM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
I like Second Skin's "Damplifier Pro" It's similar to dynamat, but higher quality and less expensive. They also offer various acoustic foams that help with absorbing noise form outside the car.
To C6 deadening questions
