I am about to replace the base radio in my 2007 L2T with a Kenwood unit.
I ordered the interface kit from Crutchfield. The kit has a single connector that interfaces with the main harness connector.
While researching how to go about replacing the radio, I saw a photo of a C6 radio and it had two places for connectors to attach.
I then went to the factory repair manual and looked at the wiring schematics. It appears that for the Base (US8) radio only a single connector is used.
Has anyone removed the base radio from their C6 and if so, can you verify if there was one connector or two.
