C6 sub and amp recommendations around $500
I am looking for more volume. I had a C5Z with 1 JL10W6 powered by a Punch 800 and it eventually blew and I replaced it with a Punch P310 that wasn't as impressive.
I'm looking for something maybe same or better and still need funds for a box. Probably one of the cubby ones.
1- Arc Audio Arc 10
1- Kenwood XR1S
1- driver side sub box
shipping
total shipped 799.99
The Arc 10 will fit into a driver side box and to me a better option than the 10w3
The 10w6 will fit but you will need a custom box and will add another 400.00 to the cost of this for the box and sub.
Since the Pioneer deck is not directly compatible with Bose, I am using a GM-CRV-1 audio line converter. ($89.00 at the time of purchase).
Subs cost me $200 each and the amp ran me just about $287. Keep in mind, this is about 7 years ago.
In short, the bass is just disgusting and insane. For Bass Heads, its perfect. For the general audio enthusiast, its overkill. But, I do have the flexibility to both worlds....Rounding out the sub-standard C5 audio system or cranking up the bass.
Currently, I have my sub power out set at -15 to keep the peace with my ears and overall listening experience. Yes, NEGATIVE 15! As I slide left to -10, -5, or even 0....Its way too much and I couldn't imagine going into the +.
Have fun.
1- Arc Audio Arc 10
1- Kenwood XR1S
shipping
What kind of power is the amp pushing and what's the rms for the sub?
Also, is there a better or alternate way to just have 1 amp and use it to power some better front 3.5" tweets too, or should I keep that separate?
Have fun.
1- Arc Audio Arc 10
1- Kenwood XR1S
shipping
this is what I will be installing!
amp has a retail of 600.00
so really this is not to bad.
If your going to spend the time to amp front speakers then you will want to go with a set of components
The most expensive part of a rear sub is the box. You can DIY an MDF enclosure for under $50, but it won't fit into a corner tub, you'd have to put it directly behind the seats.
as mentioned in the 5 channel amp
i can change out the XR1S to XR5S for same deal
I have an MDF box loaded with a Pioneer TS-SW1201S4 that I'll sell for $125 shipped if anyone wants it. I was feeding it 350wRMS from a Kenwood XR-5S and it thumped pretty hard. Coupe targa top can still be stowed in oem brackets.
PICS: 1 - 2 - 3 - 4 - 5 The lanyards are still attached (slide them under targa stowage brackets), and the recessed amp mounting area is 10"x13"
If someone buys the sub/box combo I'll even throw in a premade Add-GM24 harness if they want it
