Sponsored by: Innova
C5 ground?
Old Jun 6, 2002 | 10:49 PM
PbPedis's Avatar
PbPedis
Default C5 ground?
Does anyone know of a good place for ground within the car? I just had a new system installed and they used the -ve of the battery for ground. Now I have engine noise. On my old C5, they apparently drilled a hole and ground to the chassis, but didn't want to drill this time around.
Old Jun 6, 2002 | 11:14 PM
AP's Avatar
AP
Default Re: C5 ground? (PbPedis)
I think that you can either start my working with the RCA's ... or you should drill ... I ran mine back to the battery ... but got noise ... and when I upgraded the RCA's it went away ... you may want to try that first ...
Old Jun 7, 2002 | 02:43 PM
mrkln's Avatar
mrkln
Default Re: C5 ground? (NewVetteLover)
I have mine grounded at the battery and have no noise. :cheers:
Old Jun 7, 2002 | 06:19 PM
FarmerBob2001's Avatar
FarmerBob2001
Default Re: C5 ground? (mrkln)
A seat-belt anchor bolt is probably a good place to ground.
Old Jun 7, 2002 | 09:23 PM
AP's Avatar
AP
Default Re: C5 ground? (FarmerBob2001)
Is that a true ground?
Old Jun 8, 2002 | 10:24 PM
Ten 99's Avatar
Ten 99
The best place to ground your system is back to the battery negative terminal. The engine noise that you're hearing is not likely being introduced because of your ground. Did they run the cables and such in your car or did you? If they did, do you know how they did it? I'm specifically interested in where the RCA interconnects are run in relation to power and ground wires to your amp? If they are running next to and parallel with them, then this is most likely your source. This will introduce interference into your interconnects and this is being amplified and sent to your speakers. It's a good idea to run those things on opposite sides of the car, or at least a good 6" or so apart from one another. Also, using interconnects that employ twisted pair cabling will help reject a large part of the interference. This isn't necessary always, but can't hurt.
Good luck.
Chris
Old Jun 8, 2002 | 11:57 PM
AP's Avatar
AP
Default Re: C5 ground? (Ten 99)
Oh yeah ... the wires should be separated ... like Ten99 said ...
Old Jun 9, 2002 | 05:47 PM
_Nomad_'s Avatar
_Nomad_
From: Frankenstein never scared me. Marsupials do, because they're fassst…and they DART, THAT'S crazy!
Good luck.
Chris
Actually the battery is not the best place to ground your system, it is a last resort place to ground your system and isn’t necessary in a C3 through C5 Corvette. Running the ground back to the battery in these cars is a waste of wire and can potentially introduce noise to the system. The best place to ground to is within 2 feet of the amp(s). The shorter the ground wire the better. If you have your amps in the rear you can always ground to a seat bolt that holds the seat to the floor pan. That is a solid 12v ground and is the closest place to ground without having to drill through anything in a C4 or C5. :yesnod:
Ten 99 is right about the signal and power wires, they should be run on opposite sides of the car from one another. Also make sure your ground wire is a least the same size or larger than your power wire. ;)
Old Jun 9, 2002 | 05:52 PM
_Nomad_'s Avatar
_Nomad_
No that is not a good place to ground. Stay away from seat belt bolts. Ground to the seat bolt that bolts the seat to the floor pan. That bolt is a 12v ground.
Old Jun 10, 2002 | 12:15 AM
PbPedis's Avatar
PbPedis
Default Re: C5 ground? (The^Nomad)
Thanks for the help guys. Ten 99: they ran the cables but I would think they did not run the RCAs alongside the power. Then again, they seem too lazy to troubleshoot the problem for me, so who knows. The amp gain is now down to the point where I can't hear the whine, yet still get enough volume for my tunes, so I think I'll leave it at that for now. I don't feel like ripping the car apart to reground it.
Old Jun 10, 2002 | 01:05 AM
FarmerBob2001
Why is the seat-belt anchor bolt not a good ground? I wasn't sure about it, which is why I said 'probably'. I figured the seat-belt anchor would be bolted directly to the frame for strength. Is that not the case? Or if it is, is the frame not a good ground? Thanks.
Old Jun 10, 2002 | 01:12 AM
_Nomad_'s Avatar
_Nomad_
The seat belt bolt does bolt to the Halo frame and the frame is a good ground but the reason the bolt isn’t a good ground is because it is covered with a plastic coating to prevent rust. That coating kills the ground. Anything under 12v ground will harm the system.
Old Jun 10, 2002 | 02:18 AM
FarmerBob2001
Ah, I didn't know the bolt was covered with plastic.
What about the piece the bolt bolts to? Is it also covered in plastic? Couldn't you just scrape some of it away, and then use it as a ground? Why would they coat an 'interior' bolt to protect it from rusting?
Oh well, if the 'seat' anchor bolt works, and isn't covered in plastic, might as well use that.
Old Jun 10, 2002 | 12:30 PM
AP's Avatar
AP
Thats cool ... its a good thing to know ... its a closer to the rear ... I think that you have found the best ground in the seat bolt ...
To C5 ground?
