Sponsored by: Innova
GMOS 04 Question for a C6Z
Old Nov 10, 2012 | 10:10 PM
bchataroo's Avatar
bchataroo
Default GMOS 04 Question for a C6Z
I have one of these for my aftermarket h/u and Bose amp in my 2007 Z06. Now I am changing to an aftermarket amp. How do I connect the RCA's from the new amp to the radio?
Thanks :thumbs
Old Nov 10, 2012 | 10:36 PM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
rca cables
from amp to preouts
you will have
front
rear
sub inputs
Old Nov 11, 2012 | 08:37 AM
bchataroo's Avatar
bchataroo
Thanks for the help. Will I just disconnect the rca's and connect the new ones in? Leaving the rest intact?
Old Nov 11, 2012 | 09:07 AM
0Double D Mods
Former Vendor
you must have the c2rgm24 harness?
If so yes
disconnect the ground loop isolators and connect the rcas ones
Old Nov 11, 2012 | 11:34 AM
markcz's Avatar
markcz
If your interface adapter connects the radio to car with spliced speaker wires you can leave them as-is and just connect the new amp RCA's to the previously unused radio RCA's, then also pull AMP fuse #31 under the hood to disable oem amp/speakers.
If your interface adapter connects the radio to car via RCA cords, just unplug harness from the car end and attach RCA's that reach to the amp. You may also want to pull fuse 31 to make sure oem amp doesn't cause any issues.
Either way, you'll also need to run a power trigger wire from harness to the new amp. Odds are it's a red wire coming out of the interface adapter box. Leave it connected to the interface adapter, just splice into it for the new amp.
To GMOS 04 Question for a C6Z
