Sponsored by: Innova
Help wiring old sub tube
Old Nov 11, 2012 | 01:47 AM
The13Bats's Avatar
The13Bats
Default Help wiring old sub tube
I am not what I would call a high end car stereo person, odd since I have made a living with music,
Anyway here goes the question,
A friend has this older self amplified bass tube, he wanted me to help wire it into his stereo,
( aftermarket ) because I do enjoy doing custom wiring on vehicles,
Well, his head unit has TWO sub woofer rca outputs, the tube has what I will call one input, just two wires. ( total 4 wires on sub tube )
According to the instructions you run a hot wire and ground wire to the built in amp then you ran two other wires, one to the neg of one rear speaker and one to the pos or the OTHER rear speaker,
Seems to me this made for a mono sub, okay fine many people run subs in mono my question is can and if so how do I adapt his two rca sub outputs to this tubes two wire input?
Old Nov 11, 2012 | 11:21 AM
markcz's Avatar
markcz
The RCA output wires are a line-level signal. The wires at the speakers are speaker-level signals. If the tube doesn't have an option for RCA inputs, then you can't use the RCA's coming out of the radio (the volume would be way too low).
I'm not sure what crossing over between the left/right rears would do to the radio, if it were my car I'd just connect both tube wires on one side of the car.
Old Nov 11, 2012 | 02:15 PM
The13Bats's Avatar
The13Bats
I have no idea why they wanted the wires crossed,
Do you mean the built in tube amp will not pick up the signal from the rca outs at all?
Old Nov 11, 2012 | 04:17 PM
markcz's Avatar
markcz
If you connect the radio RCA's to the tube wires it won't sound good at all, if the automatic turn on even powers it up. You need to tap a speaker.
Old Nov 12, 2012 | 09:11 AM
Thrash's Avatar
Thrash
You should split the front speakers to the sub, will sound great and not weigh down the HU ...
To Help wiring old sub tube
