Sponsored by: Innova
Did I buy the wrong interface?
Old Dec 23, 2012 | 08:01 PM
boraxman's Avatar
boraxman
Default Did I buy the wrong interface?
I have the non-Bose single CD in my 08. I also have Onstar.
After my Pioneer install I get a buzzing through the front speakers while in backs I get sound.
I bought the PAC OS2C (non Bose w/Onstar), should I have got the Bose one instead?
I guess I should add that I have not hooked up any muting yet, maybe that makes a difference?
Old Dec 23, 2012 | 08:41 PM
okie08vette's Avatar
okie08vette
After my Pioneer install I get a buzzing through the front speakers while in back I get sound.
I bought the PAC OS2C (non Bose/Onstar), should I have got the Bose one instead?
Are you sure you have a good ground? Not sure about the muting, sounds like you may have a bad connection to the front speakers I would double check everything.
Also try the AVIC forum there is great info there just do a search and you will find it.
Old Dec 23, 2012 | 09:46 PM
boraxman's Avatar
boraxman
Well one thing I can add is that it plays Onstar very loudly through the fronts
Old Dec 24, 2012 | 08:08 PM
boraxman's Avatar
boraxman
Anybody? Car is torn apart...May need to go a different route here or put the stocker back in.
I did test my HU and its fine. Grounds are good. Im guessing I have the wrong or a defective interface?....
Old Dec 24, 2012 | 08:59 PM
okie08vette
I did have to swap out my interface and I do believe that I used the Bose, you said you got your interface from Dennis at Double D correct, if so I would call him on Wednesday he is the expert and if you do have a bad one he will swap it out for you I am sure..
Old Dec 24, 2012 | 09:11 PM
boraxman's Avatar
boraxman
No didnt get it from Dennis, probably should have though, im thinking I may need the Bose too
Old Dec 24, 2012 | 10:44 PM
okie08vette
I recommend calling Dennis anyway he is a great guy and I am sure he will be able to give you some advice.
Old Dec 25, 2012 | 02:08 AM
ZICK's Avatar
ZICK
I would have called Dennis and bought it from him
He is the man!
To Did I buy the wrong interface?
