Sponsored by: Innova
Radio buzz only with 4 RCA's
Old Jan 26, 2013 | 05:35 PM
Joebrick's Avatar
Joebrick
Default Radio buzz only with 4 RCA's
I am in the process of troubleshooting radio engine noise in a new install in my '73 and found that when front or rear RCA's are pulled at the amp the noise stops. Why would that be?
I'm hoping this leads me to something I can fix.
Amp ground, amp positive and head unit B+ are connected directly at the battery.
This is a retro sound head unit with 4 channel Sound Ordnance amp and Rockford Fosgate 6X9's
Noise is constant for Aux input or tuner...no different.
Old Jan 26, 2013 | 06:13 PM
markcz's Avatar
markcz
Does the noise change pitch/frequency with engine RPM?
If yes to above, a pair of GLI's between HU and amp should eliminate it.
It may be fixable with a different ground location. Try connecting amp ground to closest metal ground point available (you can leave current ground wire there for the test, but disconnect it at one end).
Old Jan 26, 2013 | 07:41 PM
Joebrick's Avatar
Joebrick
Yes, it does change with engine RPM. I'll try the ground change first then go after the GLI's.
Will probably ground to a seat bolt and see how that goes.
I just don't understand why it goes away with front or rear RCA's disconnected.
Old Jan 26, 2013 | 08:45 PM
markcz's Avatar
markcz
You have what's called a "ground loop". It happens with different potentials across connected components that have a common ground. Apparently your issue is somewhere between the front/rear signals.
Moving the amp ground may help, but probably not. If/when you get the GLI's try using one on just the rears first, that would leave your front signal pure at the amp (IMO GLI's don't have any effect on sound quality, but some would disagree).
Old Jan 26, 2013 | 10:02 PM
Joebrick's Avatar
Joebrick
If I ground the head unit to the battery negative terminal with the amp ground, will that remove the ground loop? i.e. all connected at one point?
Old Jan 26, 2013 | 10:45 PM
markcz's Avatar
markcz
It might, but could make it worse.
To Radio buzz only with 4 RCA's
