07 base radio settings
With the ignition on and the radio off, press the H
or the M button to enter clock mode. Press
and hold H until the correct hour appears on the
display. Press and hold M until the correct
minute appears on the display.
To change the time default setting from 12 hour to
24 hour, press either the H or the M button to
enter the clock mode. Press the tune ****
to select between the 12 or 24 hour display format.
The clock mode will automatically time out with
the changed display format set as the current
default setting.
The audio system has a Radio Data System
(RDS). RDS features are available for use only on
FM stations that broadcast RDS information.
With RDS, the radio can do the following:
• Seek to stations broadcasting the selected
type of programming
• Receive announcements concerning local and
national emergencies
• Display messages from radio stations
• Seek to stations with traffic announcements
This system relies upon receiving specific
information from these stations and works only
when the information is available. In rare cases, a
radio station may broadcast incorrect information
that causes the radio features to work improperly.
If this happens, contact the radio station.
While the radio is tuned to an RDS station, the
station name or call letters appear on the display.
RDS stations may also provide the time of day,
a program type (PTY) for current programming,
and the name of the program being broadcast.
