Sponsored by: Innova
Power Amplifier Aet Up Question
Old Feb 23, 2013 | 03:38 PM
deadman_racing's Avatar
deadman_racing
Default Power Amplifier Aet Up Question
my C4 came with an amp and a crappy sub. the amp is capable of more, so I am installing some subs I have. Here is my question:
the amp has a (BTL) level, and I do not know what is should be set at. My options are 1, .05, .3, 6, 4, 2
It is a Sony Xplod 1000w 2/1 channel XM-1652Z
I am installing 2 Kicker Comp VR Dual voice coil 4 ohm subs
Old Feb 23, 2013 | 05:28 PM
markcz's Avatar
markcz
The level adjustment is for differences in voltage coming from your radio. Start with it at 6 and turn up until you get speaker distortion at >75% volume level. The numbers refer to RCA voltage at the amp input.
That sub/amp combo won't get any more than 200wRMS to each sub if you install both subs. Best way I can see to wire it would be using only one sub and amp as 2-channel with each channel feeding a single coil on the sub for 165x2. IMO 330w from one sub will probably kick better than 200w on each of two subs, but try both to see what you like better.
Old Feb 23, 2013 | 09:04 PM
deadman_racing
Thanks! thats exactly what I needed. Since I already had the 2 sub box, I hooked them both up. It was running only 1 10" when I got it, and it did'nt sound very good. Now that I have gone through this, it may have been hooked up wrong. In the future I may try a single sub sunk in the floor like I have seen on the forum. It looks very clean.
To Power Amplifier Aet Up Question
