Sponsored by: Innova
Quick GMOS-04 Relay Question
Old Feb 26, 2013 | 12:43 PM
gdc's Avatar
gdc
Default Quick GMOS-04 Relay Question
On the gmos-04, is the relay needed when doing aftermarket amps? Or, is it just for turning on the stock bose amp if using it?
Old Feb 26, 2013 | 09:26 PM
1FUNC5's Avatar
1FUNC5
I don't use the relay either way!
Old Feb 26, 2013 | 10:32 PM
markcz's Avatar
markcz
Bypass the GMOS with the trigger, connect the HU blue wire directly to the amp, problem solved
If your radio has an 'antenna trigger' connect it to B3 on the big radio plug (or the wire on the interface side of the plug) so it will trigger the oem antenna module to power up. If no dedicated antenna trigger use the same trigger as amp on B3.
Old Feb 27, 2013 | 12:10 PM
gdc's Avatar
gdc
Thanks!
Old Sep 30, 2013 | 10:32 PM
turbosl2's Avatar
turbosl2
If you do this do you still get the chimes with the radio off?
Old Oct 1, 2013 | 11:01 AM
markcz's Avatar
markcz
Yes
Old Oct 1, 2013 | 05:23 PM
turbosl2's Avatar
turbosl2
Originally Posted by markcz
Yes
Ok, I will give it a try. I figure the trigger would only work if the radio was on. Right now I used the relay and the beeps suck or are non existant. Chimes are ok. When you hit the lock, unlock, memory seat...etc it only works sometimes. Sometimes its just static.
just to confirm you completely bypass the blue/ white stripe wire coming from the gmos, cut it right out of the loop? Antenna trigger from radio directly to b3 on 24pin connector?
Old Oct 1, 2013 | 06:52 PM
markcz's Avatar
markcz
If you already have it hooked up with a relay, then nothing will change by doing the bypass method. But yes, HU blue/white directly to B3, but you don't need to connect it to the oem wires, use the wire between the GMOS box and 24-pin GMOS plug.
Old Oct 1, 2013 | 08:59 PM
turbosl2's Avatar
turbosl2
Problem with the relay is by the time it clicks and turns the amp on the emulated beep is gone. I tried removing the relay and bypassing the gmos. Problem with that method is when the radio is off you get no power to the blue/white wire...meaning the amp is not on. The oem radio seems to activate the amp quickly for the beeps, on or off. Your method, no amp power when radio is off. No amp power no beep
Old Oct 1, 2013 | 09:19 PM
markcz's Avatar
markcz
Some adapters play chimes from an internal speaker, GMOS uses external amp and speakers, right? I was thinking it had an internal speaker like C2R-GM24 does. You'll need to keep the relay to get chimes when radio is off.
The relay should engage in under 0.1 second, if the beeps are done by the time you can hear them it's probably because of the amp having a 'soft start' feature so you're not blown away the instant the radio turns on.
Old Oct 1, 2013 | 10:31 PM
turbosl2's Avatar
turbosl2
Yes, uses door speakers for chime and beep. I am not sure about the amp, the oem radio does it fast and precise. The amp doesnt stay on because its silent until u push a button, then slitgh hiss and beep...very quick. The gmos-04 is turd, no neep unless the door chime is already going.
Old Oct 1, 2013 | 10:58 PM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
There is no need for any relay with the gmos04
not needed
do not worry about it
we send out 20-30 packages a week with this harness and install them all the time including my own car
you do NOT need any form of relay.
Everything will work just fine
its as simple as it gets to install
from radio to gmos04
red to both reds
yellow to yellow
black to black
blue white to blue white
blue to blue
green to green
green black to green black
purple to purple
purple black to purple black
white to white
white black to white black
gray to gray
gray black to gray black
the orange white dimming wire to gray with black stripe on traction control harness
there is a black with yellow stripe wire coming from the gmos04 which is used to adjust the volumes by grounding it to something in mounting cage area.
there is a blue dial on gmos o4 as well to adjust volume
This is all there is to it
no relay required
no B3
nothing
will all work just fine when done
our packages we can even wire the Maestro SW module into the gmos04 so you do not even have to cut into car harness at all
Old Oct 2, 2013 | 05:11 PM
turbosl2's Avatar
turbosl2
not needed
red to both reds
yellow to yellow
black to black
blue to blue
green to green
purple to purple
white to white
gray to gray
no relay required
no B3
nothing
This is exactly what i did the first time, and it does NOT work 100%, you will not retain all beeps on a corvette with the door closed in acc mode or car running. Chimes work when door is open, but def no beeps.
I added the relay, no improvement.
Old Oct 2, 2013 | 05:23 PM
0Double D Mods
Former Vendor
then your doing something wrong
we have NEVER used a relay and everything works just fine
Old Oct 2, 2013 | 06:46 PM
turbosl2's Avatar
turbosl2
I triple checked everything. Seems that I am not the only one with the issue. Most say the PAC works perf
To Quick GMOS-04 Relay Question
