Sponsored by: Innova
No Chimes, Speaker Audio, Nothing...
Old Mar 13, 2013 | 01:14 PM
mrpanic7's Avatar
mrpanic7
6th Gear
Default No Chimes, Speaker Audio, Nothing...
Hello everyone I have been searching non-stop and cannot seem to find anyone for a situation like this. I work at a collision repair shop, and we just finished repainting an 07 C6. All was well then the customer brings it back the next day and there is no chimes/alerts from the car, and there is no speaker audio or sound, even though the radio does turn on like normal. Everything is stock no aftermarket radio or anything aftermarket for that matter, dash works and lights up fine, HUD working, but just no sound whatsoever. Any help would be greatly appreciated.
Old Mar 13, 2013 | 01:19 PM
thepitstop2010's Avatar
thepitstop2010
I know that the chimes come from the left door speaker. That is where I would start. Verify you are getting power there by checking with a ohm meter. The meter will fluctuate with the sound levels. If no fluctuation start checking wiring between the speaker and radio.
Old Mar 13, 2013 | 01:22 PM
mrpanic7's Avatar
mrpanic7
6th Gear
Ok we will try that. Would that also affect there being no sound at all even for radio stations etc.?
Old Mar 13, 2013 | 06:17 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
Check factory amp in passenger pick panel eitHr you blew a fuse or amp is shot
Old Mar 13, 2013 | 07:36 PM
markcz's Avatar
markcz
AMP Fuse #31 under the hood would be my first check.
Old Mar 14, 2013 | 10:26 AM
mrpanic7's Avatar
mrpanic7
6th Gear
Thanks guys turns out it was the amp on the passenger side. It's fried looks like someone jumped the car backwards at one point
Truly appreciate the help!
To No Chimes, Speaker Audio, Nothing...
