Sponsored by: Innova
Help on 2012 c6 install
Old Apr 13, 2013 | 04:10 PM
Jcrumpley's Avatar
Jcrumpley
Default Help on 2012 c6 install
I just bought a 2012 c6 1LT convertible. It is not a Bose system but has on star. I had a non Bose 2007 coupe. I used a gmco to install my pioneer nav not using the factory amp. Which adapter do I need for the 2012? I don't need the on star to work. Will the gmco that I removed from the 2007 work?
Old Apr 14, 2013 | 11:26 AM
markcz's Avatar
markcz
GMCO will work fine in the '12, but I'd make sure to disable your onstar also.
Old Apr 14, 2013 | 11:59 AM
Jcrumpley's Avatar
Jcrumpley
Can you elaborate on why I need to disable on star? If I use the GMCO it won't work anyway, right. Will just pulling the fuse disable it?
Old Apr 14, 2013 | 08:12 PM
Jcrumpley's Avatar
Jcrumpley
Install done. GMCO from my 2007 worked fine.
Old Apr 14, 2013 | 09:38 PM
markcz's Avatar
markcz
Pulling onstar fuse should be fine. I guess you could say I'm a bit paranoid, but I wouldn't want onstar to have access without being able to talk to them.
To Help on 2012 c6 install
