Sponsored by: Innova
Poor sound after DD install
Old May 19, 2013 | 09:25 PM
Mallett Z's Avatar
Mallett Z
2015 C5 of the Year Finalist
St. Jude Donor '07-'08-'09
Default Poor sound after DD install
I installed a Pioneer AVIC-X940BT and the sound quality is terrible no matter which EQ setting I use. There is no bass at all. I used the PAC ROEM-VET1 harness and kept the factory bose speakers. Im wondering if I did something as simple as missed a wire for the factory door subs when i did the wiring. If i adjust the fade/balance to each corner of the car there is sound from all 4 speakers. any guidance for me to look into? Im not a stereo expert!
Old May 19, 2013 | 10:29 PM
markcz's Avatar
markcz
Did you connect all of the plugs and attach the new HU amp remote wire to whatever lines up with pin 8 of connector C1?
Old May 19, 2013 | 11:15 PM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
you need to connect the BLUE WHITE from the Pioneer to the BLUE on the ROEM-VET1
this is more than likely your problem
Dennis
Old May 23, 2013 | 01:27 AM
Mallett Z's Avatar
Mallett Z
Dennis
I thought for sure I did this right since I clearly remember your install instructions saying to do what you said above or the amps will not come on.... I just took it apart and sure enough. I hooked the blue/white to the Blue/white. LOL!
Old May 23, 2013 | 07:54 AM
0Double D Mods
Former Vendor
Glad you have it figured out
To Poor sound after DD install
