Sponsored by: Innova
alarm question
Old Jun 24, 2002 | 09:10 AM
emsrescu's Avatar
emsrescu
Default alarm question
i am puting in an alarm and my door pins are not hooked up. it said to put one wire on the + side the other to the - side do i have to put power to the swith? or do i just ground it on one side and put he - on that side and + to the otherside?
Old Jun 24, 2002 | 09:34 AM
92TripleBlack's Avatar
92TripleBlack
Default Re: alarm question (emsrescu)
They usually hook up so the switch will send a ground to the alarm unit when activated. Since you don't have ground in the fiberglass, you may have to run a ground to the switch. What brand/model is it?
Old Jun 24, 2002 | 09:45 AM
emsrescu's Avatar
emsrescu
Default Re: alarm question (92TripleBlack)
ungo
Old Jun 24, 2002 | 10:18 AM
92TripleBlack
Yeah, I used to install those. It wants a ground to be sent to the unit from the pinswitch when the door opens. The other way to hook it up is from an interior light.
Is this the diagram you are looking at or something similar? http://www.waycoolinc.com/z3/book/basic.html
Old Jun 24, 2002 | 10:33 AM
emsrescu's Avatar
emsrescu
some thing like it. my interior lite stays on so i have it disconected. that is why i have to find a way to do the door pins diffrent.
Old Jun 24, 2002 | 10:59 AM
92TripleBlack
You need to run the wires from the pin then to the negative trigger on the alarm. You should try to get your interior lights working at the same time. Chances are, they aren't working because one of the pinswitches is busted. I'd replace both and see if they work. If they do, you can get the ground from the interior light assembly which I think you have one under the dash. Makes wiring it alot easier and solves the interior light problem as well.
Old Jun 24, 2002 | 11:11 AM
emsrescu's Avatar
emsrescu
the time delay was always holding out longer and longer. so i took the bulbs out. the pins work i tested them.
Old Jun 24, 2002 | 11:21 AM
92TripleBlack
Then I would test the wire at the bulb to see if its working in sync with the pins. If it isn't and its working with the timer, tap off the pins and use that wire or replace the timer. :cheers:
Old Jun 26, 2002 | 03:43 PM
emsrescu's Avatar
emsrescu
got it thanks
Old Jun 26, 2002 | 09:45 PM
92TripleBlack
Good Deal!
Old Jun 27, 2002 | 10:06 AM
emsrescu's Avatar
emsrescu
but man was it hot it was 95 outside when i rewired it.
To alarm question
