Sponsored by: Innova
Need help with C5 remote cd changer install------
Old Jun 24, 2002 | 11:33 AM
Playswithcars's Avatar
Playswithcars
Default Need help with C5 remote cd changer install------
I know, an old subject but after searching the archives I still have questions. I am trying to install a factory 12 disc changer in my 2002 coupe. Bought the install kit with factory harness from Ken. No problem installing the changer and routing harness to the lock pillar. However, I can't seem to remove the trim pieces around the door pillars (frt &rr) and the sill cover. The biggest problem is I can find only the 1 connector under the foot rest, the female 4 wire square located at the lower right and can't locate the other connector. Someone in the archive said it would be above the body pcm and have white tape around it---well, I can't find anything with white tape or that isn't all ready plugged into a connection. Man, I fell like an idiot. Any help would be appreciated. Thanks, Bob. :confused:
