Sponsored by: Innova
A couple more ?'s before install
Old Jun 27, 2002 | 02:38 PM
reyderz's Avatar
reyderz
Default A couple more ?'s before install
OK, I have the head unit, amp for sub, amp for coaxials, sub's in the box, and I'm waiting for the equalizer and coaxials to come in the mail (I think I'm addicted to ebay). Before I start taring stuff up, do I need to remove the door panels for the coaxials or just the bose? Also, where is the best place, in the hatch area, to ground the amps?
Old Jun 27, 2002 | 03:36 PM
92TripleBlack's Avatar
92TripleBlack
Default Re: A couple more ?'s before install (reyderz86)
I'd remove the panels as they aren't to hard and it will make your job easier. Ground is good in two places: the frame, the seat screws. I grounded to the frame. I drilled a hole i the pocket behind the driver's seat and ran the wire to the ground on the frame that the power antenna uses. Short run and good ground. You need to choose your hole location carefully and seal it once the wire is through it with silicone.
Old Jun 27, 2002 | 04:21 PM
reyderz's Avatar
reyderz
Default Re: A couple more ?'s before install (92TripleBlack)
OK, thanks again Trip. I'll see if I can do this without starting any electical fires. :crazy:
To A couple more ?'s before install
