Sponsored by: Innova
connect power wire to battery
Old Jul 16, 2013 | 11:47 PM
Pittcorvette's Avatar
Pittcorvette
Default connect power wire to battery
Ok, how do you guys connect the amp to the car battery. In other words get past the firewall. Thank you for the help.
Old Jul 17, 2013 | 05:24 AM
StrangelovesM6Vert's Avatar
StrangelovesM6Vert
Pull out the battery and the carpet in the passenger footwell.
There's a grommet that holds the harness that goes through the firewall.
You can get any size cable through there if you push the grommet loose then put it back after passing your wire.
Old Jul 17, 2013 | 03:39 PM
markcz's Avatar
markcz
Smaller wires, up to about 8g, can easily be ran from engine compartment through the front quarter panel towards the door hinge, then fed into inside by going through the accordian gizmo for the door wires.
Old Jul 17, 2013 | 04:58 PM
StrangelovesM6Vert
I did that for my laser jammer wires on the driver side
To connect power wire to battery
