2 is way to small doesn't make sense to me put a 15 in
Where are you getting constant power from? If it's coming straight from battery on a new wire, then you need to install a fuse. If you're getting it from oem radio harness, then car already has a fuse so you don't even need to install a new one.
Power is coming from factory harness. I will try a 15 amp fuse. Thanks
