Sponsored by: Innova
Bose CDM question
Old Jul 25, 2013 | 04:48 PM
2012er's Avatar
2012er
Veteran: Marine Corps
Default Bose CDM question
I just finished getting all 4 amps repaired and will be installing a JVC KW-HDR81BT Double-DIN, a Metra 70-1857 Tuner Relocation and Bose Integration Harness & a Metra 99-3051 Single DIN / Double DIN ISO-Mount Installation Kit.
My question is, will I have to disconnect & remove the CDM from under the glove box or does this harness bypass it anyway?
All the new items I bought look like a simple plug and play.
I tried searching for info on this. Is there a write up on doing this swap and keeping the Bose speakers?
I've did radio installations in the pass, so I'm not scared to tackle this. I just want to get all my ducks in a row before taking the dash apart.
Old Jul 26, 2013 | 06:42 AM
2012er's Avatar
2012er
I guess no one want to help a "newbie" out........
Old Jul 26, 2013 | 09:44 AM
markcz's Avatar
markcz
Most of us regulars in this section just don't know much about C4's, sorry
Old Jul 27, 2013 | 10:00 PM
94flavette's Avatar
94flavette
I think the bypass will work without a need to remove the CDM. IIRC the CDM is still needed to signal the Bose amps to come on.
The only thing that I know needs to be changed is the antenna wire. I believe it needs to be extended to the back of your new radio.
Old Aug 17, 2013 | 01:01 PM
eutu1984's Avatar
eutu1984
2021 C4 of the Year - Modified Finalist
This may help http://www.corvettemagazine.com/tech...dern-receiver/
To Bose CDM question
